Drilling a 3/8'' hole through 5/16'' cast iron, top side of work is flat but backside is slanted. A new cobalt split point drill goes through very well but catches real bad when breaking through the backside. Don't want to force the issue and ruin the drill. Could try to slow the feed towards the end of the cut but that seems iffy. Drill press is already set at slowest speed. What about using a 4 flute end mill to finish the hole? Don't want to ruin an end mill either. Have three holes to do. What would you do? Thanks for reading.
