A buddy of mine bought a dough mixer from eBay, really nice industrial quality but the shaft was missing.
This was one of my early project when I started learning how to use the lathe. I must say I wish I picked a material other than 316 stainless to work with. As you can see at the end, I hard quite a hard time parting it off. Here I learned the hard way, when working with SS don't stop in the middle of the cut!
After some test fitting and some careful measurements I was able to produce this for him out of 316 stainless steel. This was the most difficult steel alloy I've worked with to date.
The machine has a feature when you pull the shaft up it should not come out completely but be held in place by a plastic clip. I produced the grove for this clip with a cut off tool ground to the thickness of the existing plastic C-clip. My replacement worked perfect and in doing some research was made out of better material than the original.
Chevy
Chevy
