I have been looking at buying a box of E6011 off ebay. Dang hardware store in town has went out of sight on his prices. I know some brands are known for poor quality---- what should I stay away from.:thinking:
6011 isn't particularly moisture sensitive. 7000's are generally much more moisture sensitive and may require an oven.
Moreover, I'd be concerned about any dropping or mishandling which knocks the flux off.
I usually use Hobart or Lincoln.
Did you mention to the store owner that they've lost their competitive edge?
Discussing moving you business may encourage them to adjust their prices.
Do not oven heat 60xx since it actually cracks and damages the coating and stinks-up the shop in ways you can't imagine.
I don't oven heat my rods exactly, but I did fashion a good way to store them.
I took an old "dorm fridge" - one of those small counter height refrigerators, and removed the compressor (this was way back before regulations on discharging freon). I then mounted a light bulb socket inside the unit and put a small light bulb like an oven light in it. Maybe a 20 watt bulb. Plug it in and it keeps the inside nice and warm. Maybe a hundred degrees fahrenheit or so. Warm enough to keep everything nice and dry. No problems with 6011, 6013, 7018, nickel rod, or anything else. I end up replacing the bulb about once a year.
That's new information. I didn't know that about 60xx.
Thank you!i
