I want to make this keyway slotter, but if someone has dim's for a 9" SB lathe it would be easier to make. A material list would be nice too. If not I will do it on the fly. See pic.
Thanks,
Paul
Unless you get real lucky, you'll probably have to adapt it to your individual lathe - IIRC, his was made for a 8x18 (or similar?) Just get your measurement from what ever point its gonna mount on - cross slide/compound/tool rest, or ?? to center line of spindle - go dig in the scrap box and start assembling.
This is what I ended up with for my Asian origin SB 13x36 using Mr Ishimuru's version for inspiration,
Here is one I built. Sorry I don't have the dimensions it was built on the fly.
I bored the block with the block mounted on the slide so it is concentric with the lathe bore.
