- Jun 12, 2018
- 724
Does climb and conventional milling only apply when you're milling at the edge?
What if you're milling straight into the middle of a steel block?
I get very bad chatter/vibration if I climb mill, even in very small width of cuts, hence why I just don't do it.
I'm also getting chatter and vibration when I'm sometimes cutting my endmill right in the middle of a work piece even after messing with the speeds and slow feeding. Using 3/8 carbide mostly on steel with all the axis locked tightly, with the axis I'm using the only one that's not locked. Not sure what I'm doing wrong.
I'll take a video of it later on. I have a PM25mv mill
