Not that I intend to do it (yet) but mostly for my personal education.
I have seen the suburban tool you tube video where they talked about refurbishing machines and had these large steel tables which they had scraped as reference. from my understanding you would need a larger surface as a reference, but they had 4x8 and larger tables. So their reference tables would be even larger, and they need calibrating as well, which would require even larger tables...
OK here the question, assuming one would not be able (lack of space, money, etc.) to buy a large granite table as a reference. Is there a way to scrape a steel plate flat with a reference smaller than the plate I want to scrape? For example, would it be possible to buy a 12" x 12" granite stone which is calibrated and use this to scrape an 24"x24" steel plate?
If so how would one go about it? I am aware of the three surface lapping method. but well then you end up with three plates and not one...
I am perfectly aware that this is far from economical, it just boggles my mind. In woodworking I use straight edges and winding sticks, which is mostly by eye and I don't seek perfect flatness.
If this is a stupid question, please feel free to tell me, but I am really curious
