T
TOOLMASTER
Forum Guest
Register Today
This is a jig i made over 25 years ago that i use every time i make a panel or need equal points on the corners...rubber feet for a chassis..ect..
example you want to make this with holes on the 4 corners
you hold this on the corner and mark the hole centers with a automatic center punch..
you can make any size you want, any spacing...the holes are to fit an automatic center punch.
