Fabrickator is correct, they cut amazingly well, I really don't see a need for bearings - why complicate.
I like your ball turner Fabrickator, that's how I was going to make mine, but milling on my lathe is not precise enough with the one and only vertical slide available here. The ways on the slide I had were hopeless, going from tight to loose in a matter of mm. Might have to do some experimental work with an angle plate I think.
I intend to make another for this lathe, so I'll have to experiment with methods of cutting the slot. Have not real use for it, but it's a good project. But first, another knurler with a bit of a tidy up on the slot for the adjuster screw.
