Hi All!
Several years ago I to picked up a very old, very tired, and quite beat up, NEWS, Yamatokoki Mfg Co Ltd dividing head for not a lot of $$$. It does have a 40:1 gear ratio. No tailstock, no chuck and only one dividing plate. The dividing plate is kind of a morphodite in its own right. 3 7/8" diameter, with a 13/16" center hole and 3 counter sunk mounting holes. The plate holes are 21, 23, 27, 29, 31 and 33. I seem to have a knack for finding goofy stuff like this. I guess this comes from trying to get stuff on the cheap. You should see my rotary table.
All of my stuff is very much a work in progress....
I also found a very beat up Union Mfg, 5", 3 jaw chuck, class "S" (?) the same size as the backing plate that came with the dividing head. Which are both actually 5.5" in diameter. Also for not a lot of $$$
All of this sat in the basement for a number of years until I decided it was time to move forward on this project. This past weekend I managed to get the backplate cut to fit to the chuck and mounted on the dividing head. By some miracle everything seems to be perfectly centered and true when mounted on the dividing head. Lucky me! (At least it appears so to my inexperienced eye. ) Prior to mounting the chuck on the dividing head I also skinned the outside diameter of the chuck to make it true as well. I found it odd that the outside of the chuck was so far off of true. But I think this chuck had seen a lot of crashes in its lifetime and attributed it to that.
So, now I am wanting to scribe, or engrave 360 degree markings around the outside of the backing plate and maybe on the chuck too. IDK yet as I am still working all of this out in my head. It will probably wind up being a Rube Goldberg affair with a crosslide to mount the engraver onto. Too bad that I have to keep all of this within a tight budget. If money was no object, the possibilities are endless!
So much for background info.
Now my question for you is if one turn on the crank equals = 9 degrees arc at the spindle, then one turn on the crank and 40 degrees of arc on the crank SHOULD equal 10 degrees on the spindle? Or am I mistaken in this assumption?
Some, I am sure will suggest to use the rotary table to mount the backplate onto and use the table to scribe the marks. I had thought of this but as it turns out, the table also has some kind of morphodite T slots that I haven't gotten around to making T nuts for yet. The T slots also seem to be tiny in comparison to the T slots on my lathes. So I am hoping for a way to do all of this while mounted on the dividing head and using the crank to set the divisions for the scribing operation. I was thinking that I can set the little divider arm thingy (Apology, the correct name for this thing escapes me at the moment...) on the crank\plate at 40 degrees, then do one turn + the 40 degree arc on the crank SHOULD arrive at 10 degrees at the spindle.
I was planning on scribing all of the 10 degree divisions first, then mark all of the 5 degree divisions. then scribe the individual degree marks.
I realize that this probably isn't the preferred method to get this accomplished. I'm just trying to get this done with what equipment is available to me. The time involved to get it done doesn't matter to me, as long as it gets done right the first time.
Appreciate your time to even read this long winded post.
