- Oct 12, 2023
- 93
I have been looking at the dividing heads that Precision Matthews sells, and thought of a question that I couldn't find an answer to.
Can you mill a part that's chucked up in the dividing head, while you turn it? Or can you only machine while it is locked in and stationary? Take the muzzle brake below, can those ports be machined by inserting the end mill then turning the crank to the other side then withdrawing the end mill? Yes, I know there are a lot of other variables to address with rigidity, and setups. This is just to give context to the question.
Just an example photo.
I could also just use my rotary table and then rotate the head of the mill to achieve the desired angle or create an angled setup with the rotary table. I'm just trying to figure practical and likely uses of the dividing head.
