Can't say for that one, but the Cincinnati cutter grinders just had thin plastic linear cages for the balls to keep them separated. It is far from clear in the pictures, how the ball races function.
This is a very interesting design, not sure what I think about it. The linear rail balls just ride in these cages. After taking the end caps off, it all came apart.
Not sure what to think of this design. It’s got a pair of linear rail blocks with V grooves and balls ride in these plastic cages.
Any thoughts on how to improve this design, add a bit more rigidity?
