I'm trying to disassemble a 3 way angle vise. It's an old Jet model# UAV-4 if that helps. It's just in bad shape from non-use. Once I put a little oil in the ways and got it unfrozen it seems to works very well. It has a lot of surface rust on all the bare machined surfaces (but not the ways) so I'd like to take it apart and clean it up right. I took out all the gib adjusting screws but the swiveling sections don't want to come apart.
I realized that both sides of the gibs are angled so they won't come straight up. And there isn't enough room to rotate the sections enough to get the gibs out. The only thing I can think to do is to use a punch and try to tap the gibs (half moon shaped) around to get them out. I've tried to Google instructions but there is nothing on the angle vises. Regular vises, yes, angle vises, no. I just thought I would ask if anyone has done this before and knows a trick before I screw it up.
Thanks,
Mike
Thanks,
Mike
