- Jul 14, 2024
- 5
Hi all,
I've got this watchmakers lathe... there isn't anywhere to put traditional scales, so digital indicators are the usual way to work. Also, the crossslide and indicator set up has to some on and off the lathe easily to use other attachments, like for milling and gear cutting. This is ok, as far as it goes, but I come from a 'full size' machinery background, and I'd really like full DRO functionality.
Can TouchDRO work with SPC output digital indicators, like the Mitutoyo brand ones? If the answer is 'definitely' then that's great, all steam ahead. If it's 'probably' then I'll take the plunge at my own risk.... if it's 'no' then I can just carry on with the current set up..
Thank you!
Chris
Thank you!
Chris
