Difference Between A Dc 'driver" & A Dc 'velocity Control Unit'?
Bradrock
Mar 3, 2014
60
The screw machine I bought has a Fanuc General Numeric GN3 control panel. The machine has Fanuc #5 DC servo motors with pulse coders. 108 volts 2000 rpm's.
I did not get any power supply's/drivers. I'm having zero luck trying to find out what all I need if I decide to put it back to original system.
Anyhow, while searching for Fanuc DC drivers, what I find are 'Velocity control units'
Are these actually DC 'drivers' or something different?
Every tid bit of info will be a great help to me.
Thank you, Brad
It looks like 80's tech to me? These guys should be able to talk intelligently and give you the "101" info you'll need. http://cnc-electronics.com/product-category/fanuc-drives/velocity-control-unit/
I recently did a Supermax Mill w/ an old Allen-Bradly Bandit controller. DC Servos, drives had been ripped out. cords and wires everywhere... Ugg! The encoders on the motors are probably low resolution, The tach-feedback stuff is ancient, the power consumption excessive, the power supplies all old linear stuff, on and on. I mean I get the desire. I was there once. But- I ended up putting in a Centroid AjaxCNC controller and have been nothing but happy I did. I used the same ol' motors. did a rip and replace on the old encoders and tach stuff. Put on fresh high end encoders, rewired everything so I know every inch of it. This sounds like a heck of a project!!!! Good luck.
ps- Some more pictures would really be cool to see this thing as-is.
