Die holder for the lathe...
Bob Kelly III
Oct 11, 2019
139
the last 2 days I've been scraping together enough material to make a die holder for the Logan 922
because I have a drawer full of small round dies that do not have a handle.... these dies went through the ranch fore and the die holder being aluminum melted
so I gathered them up and saved them... so I made a die holder for those tiny round dies out of a length of 3/4" pipe and a short piece of 1" pipe
and a cut down piece of solid 2" rod to reinforce the outside of that 1" pipe .... i had to re do many things many times but I finally came up with a die holder for those small round dies added a handle to it and measured the travel it had it has 5.5" of liniar travel from the tailstock forward the whole thing is probably about 15" long
... I put it in the lathe to try it out and low and behold I could not get the die to bite into the metal....thinking it was because of the diameter of the rod I stopped and trimmed down the rod some..... and went too far ( no I don't have any good measuring equipment !)
anyway.... I discovered the dies were too dull to use.... I tried to sharpen 1 with a chainsaw file but the results were less than stellar ! so looks like I did all that work for not
...but on the bright side, I do have some sharp small round dies that I will try in that die holder tomorrow !
sorry , no pictures,...... it's nothing to brag about anyway... but it looks like it will work good ! we'll see !
i figured if I can't single point thread right now, I could use the lathe to power a die holder.... or at least I thought I could LOL
any one know of a way to sharpen dies and re temper them ? I hate to throw something like them away, but it's looking like their more trouble than they're worth !
later !
Bob.........
Make sure they are cutting dies and not reforming dies . There is a difference . You also want a large lead on your stock . Give it a nice push and let your tailstock feed in . Oil on the ways is needed also if you don't like breaking things . ( ask me how I know ) :big grin:
A reforming Die ? never heard of such a thing.... though, i take it from the name, they are a specially made die that is used to re form beat up threads instead of just re cutting them ? ...very useful on threaded rod I bet !!!!!
no I am sure they are all normal dies nothing special about them except they went through the Ranch fire and are all untempered now....
I believe 1/2 of them are from Harbor freight , the cheap ones you regret buying once you open the box.... but some are good american made ones
they were in a wooden box .... and I used them on everything.... can't tell by looking now though........ same thing with the taps
one thing about my lathe it is WELL OILED ! LOL........
Bob....
The heat from the fire probably took the temper out of the dies so they are too soft to cut. Sorry for your losses in the ranch fire.
thanks ! it was the most devastating thing in my life so far ! down right rude !
....yah that is what I figured too they lost their temper.... I figure if I heat them up to cherry red and drop them in a bucket of water they will re temper but how do you sharpen something like that ? after being intensely heated the sharp edges are gone so they would have to be sharpened
maybe with a Dremel and small cylindrical stone I can get in the reliefs and grind them to a sharp edge.... but no Demel ! it's always something !
LOL......
Bob....
Was WEED in the path of the Ranch fire? That thing must have been huge.
Do a spark test. Don't bother heat treating HSS. It is difficult. If they are simple carbon steel, a torch might work. You must prevent decarburizing the teeth with some boric acid and ss foil or wire.
If the dies were carbon steel, as most of the hardware store variety seem to be nowadays, the fire would have pulled the temper. The fire shouldn't have affected any HSS dies as they would have had to be heated to a red heat to soften them. Dies are resharpened by grinding. A Dremel tool and grinding tip should work.
OK... very good ! ( love the spark test idea to tell what the metal is ! great idea ! )
that Ranch fire was so hot it melted everything Aluminum on the property.... un tempered axe heads hammers and files I had no idea burning wood would get any where near as hot as that fire did !.... I lost 6 motorcycles all melted to the ground with big puddles under them of aluminum
and the fire fighters just watched them burn they never even tried to save any of them. I would have lost my toyota pickup as well if I hadn't said to the cop hay I have to go... we'll continue your report in a bit ! and i ran down and moved my pickup which the turn signals had begun to melt.
that is the only thing I saved from the fire , that and what was in the oil shed.... it never burned..... My gyro was skirted around by the fire but the 6061 t6 aluminum turned soft..... ( de tempered)
the fire fighters were only there to keep the fire from spreading , not to save my stuff and never raised a hand in that regard, though several guns disappeared that I am sure were still repairable.... I moved into a 36' school bus I had converted to a camper, but had the engine out...
and there I lived for 4 years till the county told me I couldn't live there any more. I couldn't re build because of the Horrendous permit costs and building codes , and I couldn't get a owner/builder loan on the land... so we bought this place for zero down and got away from it all.
it was one of the hardest times in my entire life..... there is a time and place for insurance... that was it.... we didn't have any, so we were out cold
and couldn't afford to rebuild even a one room house !
....the fire started from a Bad old electrical box....... or my grinding not sure which !.... I took the wife to the airport to go on vacation with her Mom...
came back to a big column of smoke !....
..... we have fire insurance on this place anyway..... but the monthly payment is more than my SSI check !
LOL
Bob......
Wouldn't you be able to re-hardened those carbon dies by reheating to proper temps before dunking in oil or water depending on what your working with?
Yes, you should be able to in theory. What isn't known is what the alloy formulation is and therefore, what would be the hardening/quenching/tempering process. I would want to do it in an oven rather than flame hardening to better control uniformity. Packing the die in charcoal or graphite would prevent leaching carbon from the surface of the die and also prevent oxidation. I would lean towards water or brine quench rather than oil. It should give a maximum Rc. The geometry is simple enough that distortion shouldn't be an issue. I would also keep the tempering temperature low to keep the hatdness as great as possible.. Again an oven would be the beast choice for heating.when tempering.
