Die holder for lathe
MrCrankyface
H-M Supporter - Silver Member
Nov 7, 2019
485
Felt like doing one of those "shoot from the hip" projects so I started a die holder from scraps.
Always great fun machining stuff when most dimensions aren't critical, something therapeutic about seeing those chips fly. :grin:
I didn't get it perfectly concentric because I was sloppy when I re-chucked the part, hopefully it'll still work otherwise I'll have to sleeve it.
Started out with an aluminium blank that I roughed out on the lathe then milled the hex to fit the die.
Way prematurely I also knurled the piece.
I then heat-shrunk a steel part into the aluminium, the steel will act as a bushing against the linear rod I'll have in the tailstock.
And the final result looks something like this and weighs a ton. :grin::grin::grin:
I also bored out the steel backpart a bit to get some extra depth when making threads, you can see the color differences between the materials.
Overall I'm very pleased but the wobble it has kinda annoys me.
