The band saw is a 30 year old Craftsman 12 inch. Life time use is less that 10 hours. I had forgotten about steel requiring a speed reducer. I purchased a 80" (6' 8") x 1/2" x 14tpi Imachinist Metal Cutting Bi-metal M42 blade. I proceeded to cut a single 3/8 inch diameter steel rod. The cut went smoothly and quickly. I was satisfied I had solved by steel cutting problem.
I then was distracted by another project and moved on. To get to the point the next project with the band saw was to cut a 3/8 by 3 inch piece of 6061 aluminum. This was a disaster. The saw cut very slowly; less than an inch per minute. The aluminum became very hot.
Did I ruin the blade with the single steel cut? Is this the wrong blade?
The blade still eels sharp. I have been cutting steel with bi-metal reciprocating saw. Those blades seem to last for about 1 square inch before they noticeably feel dull. The band saw blade feels more like the unused end of the cut off blade then the worn cutting area.
Videos show band saws ripping through aluminum like it was wood.
