- Feb 20, 2013
- 49
Good evening gentlemen,
It's been a few years since I wrote about my little Diamond B12 mill, and I've been so busy selling one place and buying another I haven't had time to work on it. I've managed to get it running, including the vertical head attachment, unfortunately the motor is shot and I have to start it by rolling the pulleys by hand. It has very little power this way and won't engage and run in higher speeds, only the medium or slowest speeds. The motor rebuild is $350 plus I need an additional $600 in tooling to really get it going. Assuming I expend the dollars what would be your thoughts on it's long term usefulness and will the motor rebuild provide sufficient power to really do some work? I checked the runout on the table and most of the trip is within .0005" until you get to the end then it runs out .004". Seems pretty tight for a 1945 model. I really liked how the horizontal cutters work and seems like an efficient way to make slots, grooves and rabbits.
It's been very difficult to find parts for it, I think I've figured out how to get a drill chuck into the vertical head, by using a collet and straight shank chuck. I cannot find any Brown and Sharpe tooling for the vertical head except a few collets and the occasional end mill holder. The horizontal portion uses a Brown and Sharpe #9 which seems a little more versatile although I only have a 7/8" drawbar which limits me to the 2-1/2" cutters.
In conclusion, I would appreciate any experiences or insight you could provide on this little mill. I've always dreamed of having a Bridgeport and am trying to decide if I should spend the money to truly get her into production or move on to a larger machine.
