Different than what? If you are referring to dial vs. test indicator, it has a greater range and you do not have a cosine error because the indicator movement is not exactly perpendicular to the desired measurement path (it sweeps through an arc and the movement can be at a significant angle).Why is this dial indicator different how would i benifit from this
Why is it with positive and negative side when dial only goes clockwise twds positive?
Can i use this as a soft stop to measure carriage distance if it was set up as a distance measuring device? Most dials i have seen go from 0-90.
The dial can be rotated to whatever position you desire. Typically, you would pre-load the indicator to some position midway in the travel range and zero the indicator. You will then be able to measure in both directions.Why is it with positive and negative side when dial only goes clockwise twds positive?
