So I needed a way to hold my dial indicator in my Mitutoyo height gauge. I wanted to keep the design and mounting similar to the way the scribe is mounted.
Ended up taking some 1/2 inch 4140 key stock I had. Put it in the mill and copied the scribe shank portion.
Then drilled the end out. Used a .001 under reamer and cleaned up the hole. I ended up making 2 half's instead of slitting it. I don't have a blade under 1/8 inch. Drilled and tapped for a bolt that just makes a compression fitting over the dial indicator mount. Simple job but works great.
