Devcon WR-2
jackchapman
Dec 11, 2021
4
Hello. I was considering using this product to restore the ways and a couple if shaft journals on my Lathe. I have read some of the forum information on the Devcon product. How long can I expect this stuff to last? Can it be feathered or does it need a hard edge? Can it be sanded or scraped without losing its wear resistant properties? I do this for a hobby. This machine will not be used every day. Any suggestions are appreciated. I know this has been discussed before.
It is not so easy to answer your question without seeing the parts. I have filled a score in a way, but it was small and not under the area where it wears the most. A filler is not a permanent repair. IMO it is temporary. I use Devcon Aluminum as when it dries it gets shiny like cast iron. Hobby or professional, I have to know exactly where your going to fill the ways. I can't see it being used on a shaft journal of a bronze bearing rides against it. Show us some photo's.
