- Dec 22, 2014
- 222
I had converted my JET 1236 Lathe to DC with a 90V DC motor and a controller I bought from Surplus Center a few years ago.
https://rvbprecision.com/machine-to...lathe-dc-motor-conversion-jet-12-x-36-bd.html
Recently I converted my milling machine to 3 phase with a single phase to 3 phase VFD inverter and couldn't be more pleased. So I decided to do the same conversion to my lathe. This left me with a box of 90V DC parts. I recently picked up a Delta DP350 drill press with that "snowmobile" type variable speed. But it was beyond repair and there are zero parts available.
So I decided to convert it to variable speed DC drive. I had to repair the base as it had been dropped and the base was cracked where it meets the column. A piece of plate steel out of the junk pile and we were back in business.....Mount up the motor, fabricate a post to hold the controller and the tachometer....wire it up and Done!
Works fantastic! I had also converted a radial, long arm drill press to DC during covid. Here is an article about it before conversion
https://rvbprecision.com/machine-tools-welding/sprunger-rd33-radial-drill-press-refurbish.html
Photos of Delta Drill Press
