- Jan 20, 2018
- 5,913
DECKEL MILL - tools - by owner - sale
DECKEL horizontal / vertical milling machine. 40 taper spindles, all axis powered
redding.craigslist.org
Yes, but you can , mill, face and bore with the horizontal.NIce. It'd be even nicer if some horizontal arbors and an overarm support came with it.
That is a typical Euro machine, in the style made famous by Deckel/Maho. There is a quill on the vertical and on some of the Deckel's, there is a quill on the horizontal. One thing to note, you stand on the right side of the machine to operate, unlike say Bridgeport where you stand in front. The advantage to that is you can see the work when using the horizontal spindle. Also on this model shown in the ad, is that the Y slide has two mounting positions so you can reach to the far edge of the table and has a CAT 40 spindle. Also to note is that you can remove the table and use the vertical mounting face as a table, very versatile mill. The Deckel's make a Bridgeport look like a wet noodle as far as rigidity.WOW that is a very strange machine..... No table Y-axis you have to use the ram as the Y-axis and no quill so you have to run the knee all the way up to do most work.....lol
