That's exactly what would happen on mine. Got a little better after cleaning the head and the glass scale itself, but never went away. Only thing that I could think of that might work (or break things entirely) would be to dip the head into an ultrasonic cleaner. But that's if you are desperate!I sent the tech address a note and link to the video.
I'm moving the read head to the end (left) each time... So you can see the different numbers it lands on each time I bring it back to what should be zero. If I move it fast, it will be off several inches.
Ouch.Yeah. I crashed an internal threading tool in a blind hole... :| Lesson learned.
They already have a part coming my way.
You cannot move a glass scale like that and get it to read correctly, the alignment of the reader head to the scale must be of very tight specification tolerances otherwise you will get the reading errors like you show. Typically you sweep the the scale mounting position and alignment, there is also a fixed distance between the reader head and the scale. The cheaper scales are more prone to contamination due to poor lip seals, but I have used lots of glass scales in the past and have not seen a specific dead spot, as opposed to random position errors if poorly aligned or contaminated.
