Hi all, a couple of nights ago I went to switch on my mill, it twitched and then the fault light came up. I spun it a couple of times & got it to run twice, but it sounded very rough. I've looked at the mechanical components, and those look fine, so I'm guessing the roughness is one of the windings not being properly energized by the 3 phase inverter in the controller.
Looking at it it seems that the Motor is OK (a 500W 3-phase 230 volt "dc" motor) 5.5 Ohms showing between U, V, W.
I've seen a number of posts where the controllers in these give up the ghost, I've taken a look at the 6 IGBTs and testing in-situ they all look to be ok, so I'm guessing it's one of the other components & given I'm in the middle of a project I don't really want to stop and try to figure the board out.
The replacement controller from the manufacturer is $500, and frankly at the price I would prefer something more robust. Looking at ali express I see a number of "industrial" 750W 250v 1 to 3 phase VFD units at the $70-80 mark, which seems like a reasonable option I could have in 2 weeks. The bonus with these is that they have a number of additional interfaces I could play with in future.
The only issue I see currently is it looks like the motor has a hall effect unit - there's a 6-wire shielded signal cable to the motor & I can't find reasonable documentation on the VFDs (or the motor) to work out if it can be hooked up. or indeed if it's actually required. I am quite comfortable with electronics, but no specific experience with these motors.
Aside from the caviet emptor implied by the source (I'll have a fire extinguisher at the ready) is there any reason one of these off the shelf VFD units wouldn't work ?
