Hello the group. I am considering using a 1HP DC 240V shunt electric motor on my lathe, It is GE, USA made. The label states speed at rated armature and full field current (voltage) of 1725 rpm. As these motors can run at fasted speeds with field weakening, What is the safe limit. I understand much higher HP motors will state that speed but this motor does not. Is there some expected safe speed increase for these low hp motors. I would think it is a mater of bearings and armature wind strength. I would like to get 2x to 2.5x speed increase. Yes, I want it for variable speed small lathe drive. With armature and shunt control I would have enough power for a 6 or 7 to1 speed range.
I would think brush maintenance would be important.
Would an upgrade of the shaft bearings be needed ?
What speed increase were these motors designed for ?
I see this motor is not rated for continues duty. I would consider
providing adequate cooling. This is hobby / garage use. Also, back
away from full loading of motor.
Comments appreciated.
Thanks, Stan
Thanks, Stan
