Are the vfd's specifically for dc motors? I'm going to have to look for threads on this. I would love to get the how to and nitty gritty. Does the programming of the drive need altered? I am very interested in all of this.
There is a big difference between a Brushed DC motor, and a Brushless DC motor, BLDC
A Brushed DC motor runs off of Direct Current, a Brushless DC motor is actually a 3 phase motor that has a permanent magnet rotor (armature). A brushed DC motor will only run on Direct Current. (no, we're not going to get in to universal motors here)
A DC motor may have a wound or a permanent magnet field. There is a difference between a rotor and an armature, but for the purposes of this discussion, suffice it to say they perform the same function in the motor, they spin to run your machine.
Brushless DC motor
controllers are supplied with Direct Current either by a battery or a DC power supply, depending on the application, then the controller outputs 3 Phase AC to the motor.
A
Variable
Frequency
Drive is normally supplied with AC power, converts it to DC in the power supply section, which is then converted to a variable frequency, variable voltage, AC, 3 Phase output.
EDIT Corrected this sentence: "
A DC motor may have a wound or a permanent magnet armature" (armature should read field)
