Today I decided to fix the contacter in my dc panel. It hasn't worked for probably a couple of years. I have just been using the machine with forward spindle rotation all this time and thinking that sooner or later a parts machine would present itself. The parts machine hasn't come along, so I decided to take the coil out and see if I could get it repaired. Before removing it, I powered the machine up and and engaged the spindle in forward to make sure I had the right contacter. After running it in forward and confirming which contacter was which, I moved the drum switch to reverse. Nothing happened, as I expected, and I should have just stopped there and removed the bad contacter....but instead I manually pushed in the reverse contacter and the spindle turned in reverse. Again I should have stopped there....but I didn't. With the drum switch still in reverse I manually pushed in the forward contacter...thats when my trouble began. Something made noise at the bottom of the panel when I pushed in the forward contacter....I'm thinking the overload on the bottom left. The spindle didn't turn forward and now when i move the drum switch to forward the contacter pulls in but the spindle doesn't move. I tried pushing in the red button on the overload. You can feel the spring tesion, but it doesn't lock in. I checked the only two fuses that I know of (the one in the dc panel and the one in the panel back by the generator. This machine has been rewired with a rectifier to replace the exciter. Cal, you have walked me through this machine on the PM forum in the past. I'm hoping you can point me in the right direction to try and troubleshoot it again. Here's some pics of the front and rear of the panel. Thanks
Chuck
Chuck
