- Mar 22, 2022
- 381
Quick introduction so you know what you are dealing with
Retirement looms in the near future so like others here decided to build a little shop. Very limited experience with machining but some exposure. So kind of need to keep it simple and forgiving as I wander through this.
Purchased a Clausing 4904 that I suspect saw some time in a school environment
Ol #3 looks like she got some use prior to being auctioned off around 2017 to the individual I purchased from.
Good news is, ways, leadscrew, spindle look to be in reasonably good shape.
Less than good part is, it’s been crashed with the cross slide, tool post slide and compound slide all taking some damage.
And a somewhat crude repair.
I can imagine a conversation between the welding shop instructor and the machine shop instructor taking place. Obviously the school didn’t have a mill
Previous owner said it cut a slight concave on facing but never checked it out.
Cross slide with repaired area highlighted with black felt pen
Repair does not extend to the ways, not seeing unusual signs of wear.
Cross slide screw and nut are beyond help, Clausing actually had this assembly available.
cross slide is discontinued as is the compound slide.
Prior to dissembling I ran an indicator across both sides, near zero movement.
View attachment trim.66E3E591-F92D-49DF-90B6-23C9D8144DC0.MOV
Compound slide took some minor damage
And the tool post holder
How do I go about assessing the damage and overall condition of the assemblies and ways while I have it apart?
Tool post holder and compound are cast, cross slide is steel.
Clausing does have the tool post holder available. Expect that a new one would require some type of mating in to the original ways? Way out of my league here but willing to learn!
Goal is clean things up do what I can to preserve it.
Thanks
Thanks
