- Jan 27, 2017
- 184
I just purchased a Shars 'Adjust-Tru' type ER40 chuck combo with a D1-4 backplate for my PM1236.
It seems that one of the holes for the camlock studs is threaded such that whichever stud I place in that hole it is +/- 180 degrees off from the other two studs Therefore, once rotated in or out to align with the lock screws the stud (and notch) in question is higher or lower than the other two. With the backplate boss side down on the surface plate this translates to about .005 - .006 difference in the height of this stud, either higher or lower than the other two.
With the backplate installed on the lathe the stud in question either barely reaches the 3 o'clock arrow on the spindle locks or almost past the 6 o'clock arrow. With a DTI the backplate shows a high or low spot on the face or edge of the boss of about .004, where as the other two register the same.
My thinking is that this won't be an issue once I face the back plate and turn the boss; however it's aggravating that it seems to prevent it from seating fully on the spindle. Any remaining variance should be able to be adjusted out with the chuck, but I wonder about repeatability since the chuck may move on and off the lathe frequently.
Am I missing some simple solution here?
