- Oct 15, 2013
- 311
I have a Sheldon EXL56P 10" lathe (new to me). This lathe has the optional "4-inch D1 camlock spindle". I want to remove the chuck so I can give it a proper cleaning, and also want to learn about the D1 mount in the process. But I'm having trouble getting the chuck to loosen. I've turned the 3 screws CCW, 2 screws the mark lines up at ~ 12 oclock, while 1 screw goes past the indicating line to about 9 oclock. The chuck is still very solid. Is there something else I need to do to remove this chuck? Pry it loose? Put a rod in the chuck jaws to give leverage? Help please? Thanks!
