- Oct 14, 2014
- 2,115
My monarch 10EE uses D1-3 cam locks to install the chucks.
One of them has froze on too tight. I just broke my second 5/16 lathe key trying to open it. It twists right off at the base. This small a chuck key twists off pretty easy. I'll guess at maybe 75 ft.lbs.
Before I resort to drilling out the cam lock and ruining the chuck base plate I'd like to try one more time. What's the most durable key i could make?
idea one - make a holder for a 5/16 HSS tool bit.
idea two - buy a 1/2" impact 6" long extension and mill it down to 5/16 square on the end.
idea three make one out of some grade of tool steel and heat treat - need specifics to try this. Not to hot about this as my heat treat facilities are FAR from perfect.
Suggestions??
Proto 1/2" Drive Impact Socket Extension SAE J7184P | Zoro
Order Proto 1/2" Drive Impact Socket Extension SAE, J7184P at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.
www.zoro.com
Suggestions??
