Well, I finally got time to clean up and try out the 12 X 36 Craftsman lathe I recently purchased. I found the serial number, 1545 S, stamped on the far right of the ways. I was under the impression that the lathe was made around 1938, is there anyone who has a serial number table so I can verify this?
The good news, I put a dial indicator inside the spindle and it is not out-of-round. All the gears work both forward and reverse. The lead screw works fine and engages properly. No missing teeth on any of the gears. The machine is not as noisy as I thought it would be.
The bad news is that I ran all the tests on the lathe with the top gear covers removed. When I installed them and started up the lathe I heard a terrible screeching sound. Yes, the pulley was rubbing on the cover. This I can fix by grinding off a wee bit of the cover. The motor I got with the lathe has a single pulley, what are the dimensions on the double pulley that came with the machine. The motor does not have the correct mounting bracket and is held on with a piece of wood fastened to the motor by using all-thread through two of the end plate holes and then fastened to the motor mount with wood screws. Are there any illustrations of how the motor and bracket should be fastened to the counter shaft assembly. Parts of the lathe need to be painted, where do I get the beautiful blue paint that is the original color. The problem that has me puzzled is the carriage movement. The closer I get to the tail stock, the harder it is to crank the carriage. i measured the ways and got a consistent 5.750" from the headstock to the end of the ways. I haven't levelled the machine yet, but I don't know if this is causing the problem.
Some questions: what sized gears came with the lathe, where is the best place to buy replacements for worn gears, where can I get the fittings necessary to turn wood on the lathe? Another thing I noticed is that the forward and reverse gears have different tooth counts. I this the way it is supposed to be?
The steady rest I got with the lathe looks like a unit for a 9 inch South Bend or Clausing. The portion resting on the ways has one flat side and one V side. Anyone interested in trading this for a 12 in Craftsman let me know.
I am sure there will be more questions after I get it set up on a proper work bench, levelled and bolted to the floor.
Regards, Dave Nelson, Folsom, CA
