Recently purchased a used Mitutoyo 2358-50 D.I. and was hoping a member may offer repair service on such items.
D.I. is sticky and does not return reliably.
Hoping it just needs a good cleaning.
That D.I. looks pretty new , most likely all you need to do is get some alcohol on the plunger and work it back and forth . If that does not work hold it with plunger going up and drip some alc. in around the plunger . Do not use Acetone or anything that will melt the crystal .
There are not many as before, but still enough calibration and repair labs. Best of all might be Long Island Indicator, at http://www.longislandindicator.com/p123.html
Warning; read website in spare time or unsupervised by spouse, without wallet and debit cards at hand....
