- Mar 26, 2013
- 29
I'm machining a couple of special solid collet bodies with jacobs taper to hold a jacobs chuck on my Derbyshire 10mm lathe. I assumed that the taper would be 20 degrees like the 8 mm webster whitcomb collet and most of the hardinge collet styles.
When I measured the half angle to the best of my ability it seems to come up at 15 or 16 degrees or 30 to 32 degrees included angle.
Am I getting it wrong? I have searched the web and all my watchmakers lathe books and cannot find a difinitive source for the angle on the derbyshire 10 mm which seems to be the same as the Levin D
collet.
Does anyone know the correct front angle on the collet?
Thanks,
Cecil
collet.
Thanks,
Cecil
