I am assembling a team built beam engine on which all fasteners are 2-56. I purchased 100 2-56 x 3/4”, stainless steel hex head screws for this model.
I have made a couple jigs from 1/2” mild steel hex to accomplish this on my lathe. One jig is 1/4” and one is 1/2”. I drilled and tapped each jig for the 2-56 screws, and have cut several to the size required for various components. I am having trouble with the current process. I have to really tighten the screws in the jig or they catch on the parting tool and begin to screw themselves back out of the jig.
How do you cut longer screws to length? Do you have a better way to do this without buggering the threads?
BTW, I made a nut driver type tool from a socket head cap screw, piece of brass tubing and a home made wood handle for these screws that seems to do the job, although the brass hex nuts I have are bigger than the hex screw heads.
Chuck
Chuck
