Hi All,
I posted about this old Craftsman lathe a couple of months back. I've been using the time since to read and learn as much as I can about these machines. I would like to start cutting some threads but my machine seems to differ from the other 12 inch craftsman/atlas lathes I've found.
The biggest difference is that my banjo bracket has one less slot than the others I've seen. It also has a standard 32t gear on the tumbler spindle where other 12 inch lathes I've seen have a compound gear. I can't find anything stating the 32t gear is correct or if it should have a compound gear like the other 10/12 inch lathes.
Before I get too deep I was hoping someone could take a look at my gear inventory and chime in if I'm missing anything. For change gears here's what I have...
96t x 2
64t x 2
56t
54t
48t
46t
44t
40t
36t (mis-read as 35t)
32t
24t
20t
I think I'm missing at least one gear stud. Would something like this work or do the 6" parts not cross over.
LATHE-CHANGE-GEAR-BUSHING-SLEEVE-BOLT-and-NUT
Thanks in advance All,
J
96t x 2
64t x 2
56t
54t
48t
46t
44t
40t
32t
24t
20t
J
