- Jan 22, 2014
- 578
What I needed was a safe and efficient way to provide a consistent flow of cutting oil for parting, knurling, tapping and finish operations that didn’t require my having to use my hand. I don't have the room for a flood coolant system at this time, so I created a drip system that uses magnets for mounting the reservoir shelf and for the gooseneck block. I wanted the ability to move it anywhere along the splash guard, and also for use on the mill.
I’ve always liked the loc-line, modular fluid control system when I worked in a machine shop and so that’s what I used for the gooseneck. I made the remote, magnetic gooseneck block out of aluminum and knurled it to match my knobs. I found the large, donut magnets at MSC for cheap. It can be mounted to the splash guard for stationary work or to the compound for traveling cuts.
I used a hand soap bottle for the reservoir from our bathroom dispenser at work and I made the hose fitting out of a ½” bolt. I also made a vent out of an old, metal stemmed inner tube for a vacuum break which helps to provide a consistent flow. This system is not a permanent fixture on the lathe and I made it "magnetic" portable and liquid tight with the ability to drain it all back into the reservoir for storage.
