I often see warnings regarding cutting low tpi threads, for example a 3 tpi thread off an 8 tpi leadscrew.
I also see that cutting these threads with a manual crank on the leadscrew or on the lathe headstock is an acceptable workaround.
What precisely is the problem please ?
Is it a bit like going up a steep hill in a small car in a high gear ?
Where will "failure" occur ie broken plastic spur gears on a chinese lathe, broken metal gears on a SB9" or equivalent or better, jammed spur gears, broken/jammed half nuts, stalled motor, broken leadscrew ?
Or would the belts simply slip if the load was too great ? Assume a South Bend 9" 60 years old.
Bill
Bill
