- Jan 2, 2023
- 7
Hello Everyone,
I am new to this forum and hoping to find some relatively simple small projects to expand my skills base and hope that I may find some help and useful information here.
I have been machining for a little while now but consider myself to be very inexperienced. I had to upgrade my lathe recently as the motor in lathe that I had blew up and I was not able to source a replacement motor and control board. I was making a new handwheel for the cross slide of the new machine recently, which was going very well until I had to cut a keyway in the bore of the wheel. Not wanting to spend large sums of money to buy a broach kit and arbor press to do the job, I searched the internet and found a method of using a boring bar in the cross slide. It was an extremely difficult and time consuming process and the result although usable was not pretty.
This incident did however suggest a new project, "a lathe keyway cutting attachment". I was able to find a construction kit for such a device in the UK however the cost of the kit and shipping to Australia means that it would be as almost as costly as a broach kit and arbor press.
I have found a PDF of a 'lathe keyway attahment' in the downloads section of this forum but I am unable to download it. I would like to look at this file to see if it is something that I could make as I see it as a useful learning exercise. How do I get permission to download this file.
My apologies if it is at all inappropriate to post this here. I am still finding my way around the forum and likely to make a number of errors before Ihave it fully sorted out.
