- Dec 30, 2021
- 60
I'm trying to cut an internal 3/4-16 in 12L14 stock.
The threads start, but before I am more than a few thousands deep, the cutter digs in hard enough to shift the part in the three jaw chuck.
I'm advancing .003 on every pass. I have done a handful of passes at the same depth (not sure if these are called spring passes when threading) just to make sure that I'm properly clearing the threads. I think the grab is somewhere around .030". I was trying to do .005 a pass and had the grab issue and dropped to .003. Not sure if I need to go further down from there.
I have a solid carbide internal threading tool (meant to get a shorter boring bar and bought this instead), so I don't think it's the tool.
I am backing out the cutter when I return to the starting position. The thread depth that is cut before the grab look pretty clean to me.
I'm going to step away from the tool for a bit and try making the part in Aluminum tomorrow. I'd sure appreciate any tips on how I might improve this setup.
Thanks,
Andy
Thanks,
Andy
