Hey Guys,
Forget all that other greasy kid's stuff...
Move on up to the 21st century with BOELUBE®, in the paste. It's from Boeing!
Fantastic stuff for a home shop that doesn't want to run flood or mist. Just brush some on and go.
Available from MSC, Travers, Etc.
Here's some "official" information about it I copied:
"Unique Chemistry Manufactured from personal care ingredients, BOELUBE® is non-toxic, non-irritating and environmentally safe. BOELUBE® is non-corrosive, non-flammable, chemically stable, and free of halogens, heavy metals, sulfur, phosphorus, silicone, petroleum and paraffin wax. BOELUBE® does not contain any ingredients considered a hazardous substance by OSHA, WHMIS, IARC, NTP, and State Regulatory Lists. Refer to Material Safety Data Sheets for additional information.
High Efficiency Lubrication - High lubricity and unique polar properties are the keys to its ability to provide superior metalworking lubrication.The application of minute amounts of BOELUBE® , which is consumed in the metalworking process, will greatly improve tool life , surface finish and hole quality. BOELUBE® provides superior lubricity when machining materials such as aluminum and titanium where high quality finish and increases of 200% or more in tool life is observed. Cost savings are derived through longer tool life, increased productivity, reduced lubricant usage, lower shop maintenance costs, and clean chips, parts and machinery.
Advantages - BOELUBE® will not promote dermatitis and presents a safe effective method for operators to machine various types of metal, composites, graphite, etc. without special handling or typical disposal problems.
BOELUBE® is easily removed with water-based cleaner, isopropyl alcohol or denatured alcohol. In most cases BOELUBE® does not have to be removed prior to heat treat, and may be compatible with paints and sealants (testing is recommended and should be performed). BOELUBE® may also be left on the work piece for subsequent machining or as a corrosion inhibitor .
Application - BOELUBE® is available in Liquid, Paste, Solid and Water-Soluble form. Applications include Abrasive Belts, Bending, Cold Working, Deburring, Drilling, Drop Hammer, Forming, Grinding, Milling, Punching, Reaming, Routing, Sawing and Tapping. The choice of which physical form to use will depend on the operation, material type, speeds and feed rates."
No connection to Boeing (I am Ex-Grumman), now just a happy user.
Save the bacon fat for breakfast ;-)
G'luck
PaulS
