Hi Everyone,
I am new to this forum.
I am wondering if you have help me.
I am trying to make some simple cuts and put some countersink holes. But the material is Chrome Carbide Overlay plate. And that is the problem. Chrome Carbide Overlay plate runs in the 63-67 Rockwell C range. "Normal" metal cutting blades and bits are useless. We can Plasma cut the material - which is good for rough cutting. We can water-jet or laser-cut - but we don't have this equipment inhouse and therefore it is time consuming and expensive. We can cut with Abrasive disc but even the small cuts will require a couple of discs to cut the piece.
Any recommendations for blades/tools to cut this hard of material using a chop saw, band saw or vertical mill would be greatly appreciated.
Jeff
Jeff
