- Feb 14, 2014
- 28
Hello gang, I had a part I needed to have done today. I needed to get a 3/16" keyway into a 3/4" diameter hole, 1.25" deep. I had a piece of 3/16" square tool steel and guessed at how it should be ground. I used a 1/2", 90 degree boring bar to hold the cutter. I took about .005" per cut until I got it to .090" cutout.
The issue I had the most trouble with was deep chips. I bored the hole to .75" and 1.375" deep. The 11/16" pilot hole drill went about an 1/8" deeper to let the key cutting tool go deep enough. As I went through the many cuts I couldn't remove some of the chips at the end of the cut. My keyway ended up being only 1.125" deep when I finished.
Is the only way to get the full key to the end to bore more depth for the build up? Or is their a better way to grind my tool to make the chip come out? I thought about moving the saddle back every pass or two in order to break chips at the end, but that would add a considerable amount of time to the job.
Here are a couple of pictures of the tool and the end result.
