We resize sheets of MIC6 1/2" aluminum (cast 7000 series) tooling plate with a hand held circular saw. Also do same on smaller pieces on the table saw. Strictly speaking the wood working tool speed is way too high for aluminum and finer blades only aggravate that. I've found coarser carbide tipped combo andeven rip blades clear chips and work better. I also apply a little grinders grease across the saw tips before I start and between cuts, which serves as lube, helps cutting, reduces heat, and reduces aluminum adhesion to teeth which you should check and remove as necessary.
Heat generation can be a problem particularly if you are underpowered. The circular saw was nothing special and handled full depth of cut but it's tough duty for the saw. A few cuts is no problem but definitely shorter life indedicated service. Thegear reduction drives are always the weak point. The table saw is 10"/3HP and no problem there. Cuts 1/4" like it's not even there. You can get into trouble if you stall the cut or wedge the blade as it can/will very quickly over heat and distort the blade. You can always take several passes, especially if ripping with a fence. It's a tough life for the blade. I use cheap ones. They'll occassionally lose some tips. Wear a face shield. The aluminum chips are hot.
Best,
Kelly
