- Aug 4, 2018
- 21
So I've got my new PM-25 all set up with the x-axis power feed, mist cooler, etc. For my first "real" milling job I need to cut a .180" slot into a 3/8" bar of copper. The slot will be about 1" long. I've got a 1/8" two-flute HSS endmill. When I use G wizard to calculate feeds and speeds it says that if I cut .07" deep, it would have a deflection of 94%. That's at 1 ipm.
Is that the right way to do this? Total it would be 12 passes at 1 ipm to cut the whole slot? Should I cut the slot all the way through at 1/8", and then cut the rest of the slot after? Should I cut the slot to the right dimension on each pass?
Thanks!
Thanks!
