Imagine a shaft protruding from a block of steel, basically non-removable. I need to cut a chamfer all the way around the base of the shaft as a locating feature. Shaft is 1" dia, 12" long, block size unimportant. Fixturing in a lathe could probably be possible but would be non-viable in this instance.
Closest tool I can think of would be an annular cutter, but it would have to be bored completely through, and the teeth at an angle to cut at an angle instead of flat. Tool could be turned by hand, as the steel should be relatively soft and the chamfer does not need to be deep or wide. Something designed like a Neway cutter would work too. It's for a one off job, and can't be hellaciously expensive.
Any ideas for something preexisting?
