- Jul 20, 2014
- 1,386
I need a small triangular shaped (three leges) steel stand. I've made these before, but by using 3 stock steel flat bars and welding them all together.
This is smaller, approx. 3.5 x 3.5" Can this shape be cut whole from a square plate of steel? If so, what is the best way or should I just weld? (more work).
See attached photo. (lower right). The round bar will be welded after a press fit. This base will not be supporting a lot of weight, around 6 lbs. max.
Just need it to be sturdy, little to no flex. This is an art sculpture armature stand.
