Cutter ID help
AGCB97
H-M Lifetime Diamond Member
Apr 22, 2016
987
I received this cutter with a LOT of tools from EBAY. I think it is a counterbore cutter but don't understand the outside ring (unless it is just a depth stop). The cutter part is 1 5/8" D. Shank is 1/2" w/ 3 flats. Pilot is removable, I assume to change sizes. Looks like an expensive tool and it's new.
Tell me if you recognize it and what it might be worth.
Thanks
Aaron
Ahh! forgot to include that.
and mine as well---- With the hex shank, I'd guess would be that it was intended to be used by hand for some special task.
Yep , spot-facing tool mostly used on castings .
