I spent a little time today adjusting the gibs on my new Monarch. It didn't take very long to figure out why the cross slide was so loose. The gib adjustment screw was binding in it's hole (slightly bent...); it felt tight, but there was about 1/4" of play between it and the gib. Once I rectified that, I got the gib adjusted so that cross slide is firm, but not tight, the problem is that the gib is sticking out the back of the cross slide by about 1/4". What's the protocol here? Do I just pull the gib out, cut off the excess, debur, and replace? Is there something I'm missing? I figured I would post this before I just started hacking away at things...
DMS
DMS
